View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
L3–VSN field descriptions
Use the data in the following table to use the L3–VSN tab.
 Name  |
 Description  |
 VrfId  |
 Specifies the VRF ID of the VRF corresponding to the Layer 3 VSN I-SID.  |
 Isid  |
 Specifies the Layer 3 VSN I-SID.  |
 VrfName  |
 Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID.  |
 InjectDefaultRouteDisable  |
 Specifies whether injection of default routes is disabled.  |
