Configure a target table to specify the list of transport addresses to use in the generation of SNMP messages.
 - Click Target Table.
 - In the Target Table tab, click Insert.
 - In the Name box, type a unique identifier.
 - In the TDomain box, select the transport type of the address. Select either ipv4Tdomain or ipv6Tdomain.
 - In the TAddress box, type the transport address and User Datagram Protocol (UDP) port.
 - In the Timeout box, type the maximum round trip time.
 - In the RetryCount box, type the number of retries to be attempted.
 - In the TagList box, type the list of tag values.
 - In the Params box, type the SnmpAdminString.
 - In the TMask box, type the mask.
 - In the MMS box, type the maximum message size.
 - Click Insert.
Target Table Field Descriptions
Use the data in the following table to use the Target Table tab.
 Name  |
 Description  |
 Name  |
 Specifies a unique identifier for this table. The name is a community string.  |
 TDomain  |
 Specifies the transport type of the address. ipv4Tdomain specifies the transport type of address is an IPv4 address. ipv6Tdomain specifies the transport type of address is IPv6. The default is ipv4Tdomain.  |
 TAddress  |
 Specifies the transport address in xx.xx.xx.xx:port format, for example: 192.1.2.12:162, where 162 is the trap listening port on the system 192.1.2.12.  |
 Timeout  |
 Specifies the maximum round trip time required to communicate with the transport address. The value is in 1/100 seconds from 0–2147483647. The default is 1500. After the system sends a message to this address, if a response (if one is expected) is not received within this time period, you can assume that the response is not delivered.  |
 RetryCount  |
 Specifies the maximum number of retries if a response is not received for a generated message. The count can be in the range of 0–255. The default is 3.  |
 TagList  |
 Contains a list of tag values used to select target addresses for a particular operation. A tag refers to a class of targets to which the messages can be sent.  |
 Params  |
 Contains SNMP parameters used to generate messages to send to this transport address. For example, to receive SNMPv2C traps, use TparamV2.  |
 TMask  |
 Specifies the mask. The value can be empty or in six-byte hex string format. Tmask is an optional parameter that permits an entry in the TargetAddrTable to specify multiple addresses.  |
 MMS  |
 Specifies the maximum message size. The size can be zero, or 484–2147483647. The default is 484. Although the maximum message size is 2147483647, the device supports the maximum SNMP packet size of 8192.  |
