Use the following procedure to configure a collector for IPFIX. Use the ExtremeAnalytics™ solution as the collector.
You can configure IPFIX on Segmented Management Instance interfaces VLAN and CLIP. You can also use routing VLANs or loopback IPs as the exporter IP address. Configure the exporter IP address to match the Management Instance interface IP address.
 - Select IPFIX.
 - Select the Collector tab.
 - Click Insert.
 - In the Num field, specify a value for the collector ID number.
 - In the AddressType field, specify a value for the IP address type of the collector.
 - In the Address field, specify a value for the IP address of the collector.
 - Optional: In the SrcPort field, specify a value for the source port sending flow information.
 - Optional: In the DestPort field, specify a value for the destination port receiving flow information.
 - In the ExporterIpType field, specify a value for the IP address type of the exporter for the collector.
 - In the ExporterIp field, specify the IP address of the exporter for the collector.
 - Optional: In the ExportInterval field, specify the frequency of template packets exports to the collector.
 - Optional: In the InitialBurst field, specify the number of template packets to send when the collector becomes reachable.
 - Select Insert.
Collector Field Descriptions
Use the data in the following table to use the Collector tab.
 Name  |
 Description  |
 Num  |
 Specifies the ID number of the collector  |
 AddressType  |
 Specifies the IP address type of the collector.  |
 Address  |
 Specifies the IP address of the collector.  |
                         Protocol  |
                         Specifies the protocol used to export data from the exporter to the collector.  |
                         SrcPort  |
                         Specifies the source port sending flow information. The default value is 2055.  |
                         DestPort  |
                         Specifies the destination port receiving flow information. The default value is 2055.  |
                         ExporterIpType  |
                         Specifies the IP address type of the exporter for the collector.  |
                         ExporterIp  |
                         Specifies the IP address of the exporter for the collector. Note:
                    For Segmented Management Instance interfaces, the exporter-IP address is the IP address of the Segmented Management Instance interface on which datagrams egress.  |
                         State  |
                         Specifies the state of the collector. The default value is enabled.  |
                         IsReachable  |
                         Specifies whether the collector is reachable. The default value is false (not reachable)  |
                         ViaNextHopName  |
                         Specifies the next-hop through which the collector is reachable.  |
                         ExportInterval  |
                         Specifies, in seconds, the frequency of template packets exports to the collector. The default value is 60 seconds.  |
 InitialBurst  |
 Specifies the number of template packets sent when the collector becomes reachable. The default value is 5.  |
