Associate a port to a Virtual Router Forwarding (VRF) instance so that the port becomes a member of the VRF instance.
You can assign a VRF instance to a port after you configure the VRF. The system assigns ports to the GlobalRouter, VRF 0, by default.
- In the Device Physical View tab, select a port.
 - Click General.
 - Click the VRF tab.
 - To the right of the BrouterVrfId box, click the ellipsis (...) button.
 - In the BrouterVrfId dialog box, select the required VRF.
 - Click OK.
 - Click Apply.
VRF field descriptions
Use the data in the following table to use the VRF tab.
 Name  |
 Description  |
 VrfIds  |
 Shows the VRF ID.  |
 VrfNames  |
 Shows the VRF name.  |
 VrfCount  |
 Shows the number of VRFs to which the port is associated.  |
 BrouterVrfId  |
 Specifies the VRF ID for a brouter port.  |
 BrouterVrfName  |
 Shows the VRF name for a brouter port.  |
