Flush or clear the routing tables for administrative and troubleshooting purposes. The clear and flush commands perform the same function; they remove the contents of the table.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config-if)#action flushAll Switch:1(config-if)#exit Switch:1(config)#clear ip route gigabitethernet 1/1
The following table defines parameters for the clear ip route gigabitethernet command.
 Variable  |
 Value  |
 {slot/port[/sub-port]}  |
 Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
