Perform this procedure to verify that the software files are downloaded properly to the switch. The MD5 checksum for each release is available on the Extreme Networks Support website.
Download the MD5 checksum to an intermediate workstation or server where you can open and view the contents.
Download the image file to the switch.
Calculate and verify the MD5 checksum after you download software files.
View the contents of the MD5 checksum on the workstation or server:
3242309ad6660ef09be1b945be15676d VSP8200.4.0.0.0_edoc.tar d000965876dee2387f1ca59cf081b9d6 VSP8200.4.0.0.0_mib.txt 897303242c30fd944d435a4517f1b3f5 VSP8200.4.0.0.0_mib.zip 2fbd5eab1c450d1f5feae865b9e02baf VSP8200.4.0.0.0_modules.tgz a9d6d18a979b233076d2d3de0e152fc5 VSP8200.4.0.0.0_OpenSource.zip 8ce39996a131de0b836db629b5362a8a VSP8200.4.0.0.0_oss-notice.html 80bfe69d89c831543623aaad861f12aa VSP8200.4.0.0.0.tgz a63a1d911450ef2f034d3d55e576eca0 VSP8200.4.0.0.0.zip 62b457d69cedd44c21c395505dcf4a80 VSP8200v400_HELP_EDM_gzip.zip
Calculate the MD5 checksum for the file on the switch:
Switch:1>ls *.tgz -rw-r--r-- 1 0 0 44015148 Dec 8 08:18 VSP8200.4.0.0.0.tgz -rw-r--r-- 1 0 0 44208471 Dec 8 08:19 VSP8200.4.0.1.0.tgz Switch:1>file-checksum md5 VSP8200.4.0.0.0.tgz MD5 (VSP8200.4.0.0.0.tgz) = 80bfe69d89c831543623aaad861f12aa
The following table defines parameters for the file-checksum md5 command:
                                 Variable  |
                                 Value  |
                                 WORD<1-99>  |
                                 Specifies the file name.  |
