This procedure applies only to the VSP 7400 Series.
Perform this procedure to display Level 1 remote area information. Remote Intermediate-System-to-Intermediate-System (IS-IS) provides support for hierarchical routing, which enables the system to partition large routing domains into smaller areas. Remote IS-IS uses a two-level hierarchy, dividing the domain into multiple Level 1 areas and one Level 2 area. The Level 2 area serves as backbone of the domain, connecting to all the Level 1 areas.
Important
Important
The IEEE 802.1aq standard currently only defines the use of one hierarchy, Level 1. Level 2 function is disabled.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the L1 Area tab.
L1 Area Remote Field Descriptions
Use the data in the following table to use the L1 Area Remote tab.
Name
Description
AreaAddr
Specifies an area address reported in a Level 1 link-state packets (LSP) that the system generates or receives through the Intermediate System.
