Use the following procedure to install the Root CA certificate obtained offline.
This procedure applies to VSP 8600 Series only.
 - Select System Log.
 - Select Root Certificate Table tab.
 - Select Insert.
 - In the Filename field, enter the filename obtained offline from the CA.
 - In the Action field, select the action.
 - Select Insert.
Root Certificate Table field description
Use the data in the following table to use the tab.
 Name  |
 Description  |
 Filename  |
 Specifies the certificate filename obtained offline from the Root Certificate Authority.  |
 Action  |
 Specifies the action to be performed on Root CA.
 The system displays the Conversion Fail if the execution of the action fails.  |
