This procedure only applies to VSP 8600 Series.
View the storage usage for modules in the chassis.
You cannot perform this procedure on hardware platforms with fixed configurations. It is only available for platforms where you can install modules in slots.
  1. In the Device Physical View tab, select a module slot.
  2. In the navigation pane, expand Configuration > Edit.
  3. Select Card.
  4. Select the Storage Usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
Name
Description
IntflashBytesUsed
Specifies the number of bytes used in internal flash memory.
IntflashBytesFree
Specifies the number of bytes available for use in internal flash memory.
IntflashNumFiles
Specifies the number of files in internal flash memory.
UsbBytesUsed
  Specifies the number of bytes used in USB device.
UsbBytesFree
Specifies the number of bytes available for use in USB device.
UsbNumFiles
Specifies the number of files in USB device.
