This procedure does not apply to VSP 8600 Series or XA1400 Series.
Perform this task to configure the time, in seconds, for Auto-sense to wait for a Link Layer Discovery Protocol (LLDP) neighbor to be detected in the Auto-sense wait state before transitioning to the Auto-sense onboarding state.
Configure the Auto-sense wait interval as 50 seconds:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense wait-interval 50
Verify the Auto-sense wait-interval information:
Switch:1>show auto-sense wait-interval
                                 AUTO-SENSE GLOBAL Config
WAIT
INTERVAL
50
0 out of 0 Total Num of AUTO-SENSE entries displayed
The following table defines parameters for the auto-sense wait-interval command.
                                 Variable  |
                                 Value  |
                                 <10-120>  |
                                 Specifies the wait interval, in seconds, for Auto-sense ports. The default value is 35.  |
