Configure the target table to configure the security parameters for SNMP. Configure the target table to configure parameters such as SNMP version and security levels.
 - Click Target Table.
 - Click the Target Params Table tab.
 - Click Insert.
 - In the Name box, type a target table name.
 - From the MPModel options, select an SNMP version.
 - From the Security Model options, select the security model.
 - In the SecurityName box, type readview or writeview.
 - From the SecurityLevel options, select the security level for the table.
 - Click Insert.
Target Params Table Field Descriptions
Use the data in the following table to use the Target Params Table tab.
 Name  |
 Description  |
 Name  |
 Identifies the target table.  |
 MPModel  |
 Specifies the message processing model to use to generate messages: SNMPv1, SNMPv2c, or SNMPv3/USM.  |
 SecurityModel  |
 Specifies the security model to use to generate messages: SNMPv1, SNMPv2c, or USM. You can receive an inconsistentValue error if you try to configure this variable to a value for a security model that the implementation does not support.  |
 SecurityName  |
 Identifies the principal on whose behalf SNMP messages are generated.  |
 SecurityLevel  |
 Specifies the security level used to generate SNMP messages: noAuthNoPriv, authNoPriv, or authPriv.  |
