View the IPv6 address bindings that IPSG allows.
 - Click IPv6.
 - Click the Source Guard Binding tab.
Source Guard Binding field descriptions
Use the data in the following table to use the Source Guard Binding tab.
 Field  |
 Description  |
 IfIndex  |
 Specifies a value that uniquely identifies the port.  |
 IPv6Addr  |
 Specifies the binding entry for the IPv6 address.  |
