        Functionality is combined with other RADIUS attributes and EAPoL configurations to create
            untagged S-UNIs.
        This attribute supports the following combinations:
            - untagged EGRESS-VLAN-ID + VLAN:ISID
                -> VLAN from S-UNI becomes untagged
                vid[NEW_RADIUS_VID] + autoIsidOffset -> create S-UNI for I-SID
                (VLAN+autoIsidOffset)
            From the RADIUS attributes, for untagged VLAN 15. The VLAN from S-UNI becomes
                untagged:
            Egress-VLANID = "838860815" (untagged vlan 15)
Fabric-Attach-ISID += "15:23513"
            The following example results in the value 0:1015 for creating an untagged S-UNI.
            From the RADIUS attributes, for untagged VLAN 15 and RADIUS-assigned VLAN. Creates
                S-UNI for I-SID (VLAN+autoIsidOffset):
Tunnel-Private-Group-Id = "15"
            From the EAP configuration:
            eapol auto-isid-offset 1000
eapol auto-isid-offset enable
            Consider the following when using this attribute:
                - Any combinations with
                    EGRESS-VLAN-ID for a tagged VLAN are ignored.
                - When EGRESS-VLAN-ID and VLAN:ISID
                    binding attributes are used, the VLAN must have the same value.
                - The RADIUS server can provide
                    more than one VLAN:ISID binding but one must match the VLAN used in
                    EGRESS-VLAN-ID to create an untagged S-UNI.
                - Only one EGRESS-VLAN-ID attribute
                    is used. If more than one is found in the packet, only the first one is
                    used.
                - If the untagged S-UNI is derived from
                    EGRESS-VLAN-ID + VLAN-ID + VLAN attribute + auto-isid-offset, the packet must
                    not contain any S-UNI bindings.
