This procedure does not apply to VSP 8600 Series.
Use this task to view TCP statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IP/IPv6 TCP tab.
IP/IPv6 TCP Field Descriptions
Use the data in the following table to use the IP/IPv6 TCP tab.
 Name  |
 Description  |
 IPVersion  |
 Shows the IP address version as ipv4 or ipv6.  |
 ActiveOpens  |
 Shows the active open TCP connections statistics.  |
 PassiveOpens  |
 Shows the passive open TCP connections statistics.  |
 AttemptFails  |
 Shows the TCP connection attempt failures statistics.  |
                 EstabResets  |
                 Shows the TCP connection esablished resets statistics.  |
| InSegs |
                 Shows the input segments statistics.  |
| OutSegs |
                 Shows the output segments statistics.  |
| RetransSegs |
                 Shows the retransmit segments statistics.  |
| InErrs |
                 Shows the input checksum errors statistics.  |
| OutRsts |
                 Shows the output resets statistics.  |
| InCsumErrors |
| Clear |
                 Specifies to clear the statistics. Default is false.  |
