This procedure does not apply to XA1400 Series or VSP 8600 Series.
Configure Link Debounce for ports to hold the connection path until the carrier side switchover is complete.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
link-debounce <0-300000>
show interfaces gigabitEthernet link-debounce [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Configure the Link Debounce timer on port 1/2 to 300000 milliseconds.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#link-debounce 300000
Display the Link Debounce configuration for ports 1/1 through 1/4.
Switch:1>enable
Switch:1(config)#show interfaces gigabitEthernet link-debounce 1/1-1/4
                               Port link debounce
PORT     LINK-DEBOUNCE     LINK-DEBOUNCE         DEBOUNCE    DEBOUNCE
NUM      STATUS            TIMER MILLISECONDS    COUNT       SUCCEEDED
1/1      Enable            1500                   0           0
1/2      Enable            300000                  0           0
1/3      Disable           --                     0           0
1/4      Enable            4000                   0           0
