Use this procedure to configure the certificate authority (CA) to use Simple Certificate Enrollment Protocol (SCEP) with a CA server for online certificate provisioning.
Switch:1>enable Switch:1#virtual-service FIGW console FIGW>set certificate ca-trustpoint caExtremeEJBCA ca-url http://192.0.2.9:8080/ejbca/publicweb/apply/scep/test/pkiclient.exe FIGW>set certificate ca-trustpoint caExtremeEJBCA caname subca5 FIGW>set certificate ca-trustpoint caExtremeEJBCA get-method post
The following table defines parameters for the set certificate ca-trustpoint command.
 Variable  |
 Value  |
 <ca-label>  |
 Specifies the name of the certificate authority (CA). The name can use alphanumeric characters and is case-sensitive. The maximum length is 45 characters.  |
                                 ca-url <ca-url>  |
                                 Specifies the trusted CA URL.  |
 caname <caname>  |
 Specifies the name of the owner of the device or user.  |
 get-method <post | get>  |
 Specifies the HTTP request style. You can use post for EJBCA or get for Win2012 CA. The default value is post.  |
The following table defines parameters for the certificate ca command.
                                 Variable  |
                                 Value  |
                                 <ca-trustpoint>  |
                                 Specifies the name of the certificate authority. The name can be alphanumeric and is case-sensitive. The maximum length is 45 characters.  |
                                 <subject-label>  |
                                 Specifies the subject identity.  |
The following table defines parameters for the certificate get command.
                             Variable  |
                             Value  |
                             cacert-from <A.B.C.D> <user> <file-path>  |
                             Specifies where to obtain the CA certificate. Specify the IP address, username, and remote file path.  |
                             crl-from <A.B.C.D> <user> <file-path> <cacert-filename>  |
                             Specifies where to obtain the Certificate Revocation List. Specify the IP address, username, remote file path, and the CA certificate file to verify the CRL.  |
                             signedcert-from <A.B.C.D> <user> <file-path> <subject-label>  |
                             Specifies where to obtain the subject certificate. Specify the IP address, username, remote file path, and subject label.  |
