Unable to Log On by any Means
If you cannot log on by any means, perform the following steps.
Rlogin is only supported on VSP 8600 Series.
Check if you enabled both TACACS+ and RADIUS on the switch:
Switch:1>enable
Switch:1(config)#show tacacs
Global Status:
   global enable : false
   authentication enabled for : cli
   accounting enabled for : none
   authorization : disabled
   User privilege levels set for command authorization : None
Server:
                      create :
Prio   Status  Key     Port  IP address  Timeout Single Source SourceEnabled
Primary NotConn ******   3    192.0.2.254      30   true 5.5.5.5  true
Backup  NotConn ******  47    198.51.100.1      10  false 0.0.0.0 false
Switch:1>show radius
             acct-attribute-value : 193
                      acct-enable : false
        acct-include-cli-commands : false
        access-priority-attribute : 192
             auth-info-attr-value : 91
         command-access-attribute : 194
           cli-commands-attribute : 195
                    cli-cmd-count : 40
               cli-profile-enable : false
                           enable : false
                 igap-passwd-attr : standard
           igap-timeout-log-fsize : 512
                        maxserver : 10
            mcast-addr-attr-value : 90
             supported-vendor-ids : 1584, 562, 1916
                      secure-flag : false
Check if the administrative and operation status of the port is up:
Switch:1#show interface gigabitethernet 1/2
                                 Port Interface
PORT                       LINK  PORT           PHYSICAL          STATUS
NUM   INDEX DESCRIPTION    TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE
1/2   257   1000BaseTX     true  false    1950  00:24:7f:a1:70:61 up     up
                                   Port Name
PORT                                               OPERATE  OPERATE  OPERATE
NUM   NAME                           DESCRIPTION   STATUS   DUPLEX    SPEED    VL
AN
1/2                                  1000BaseTX    up       full     1000     Ta
gged
                                  Port Config
PORT                DIFF-SERV   QOS   MLT   VENDOR
--More-- (q = quit)
Check if the switch has a route configured to the server network:
Switch:1(config)#show ip route
                                     IP Route - GlobalRouter
                                                     NH                  INTER
DST             MASK            NEXT                 VRF/ISID       COST FACE  PROT AGE TYPE PRF
198.51.100.1        255.255.255.255 192.0.2.65       GlobalRouter     1   100   OSPF 0   IB   125
198.51.100.5         255.255.255.255 192.0.2.5        -               1   0     LOC  0   DB   0
198.51.100.13        255.255.255.255 			          GlobalRouter     10  1000  ISIS 0   IBS  7
198.51.100.200       255.255.255.255 			          GlobalRouter     10  1000  ISIS 0   IBS  7
4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed.
TYPE Legend:
I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout
e,
U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route
PROTOCOL Legend:
v=Inter-VRF route redistributed
      Check if the Segmented Management
                                Instance has a route configured to the server
        network:
Switch:1(config)#show mgmt ip route
                         Mgmt IPv4 Route Information - Table main
DEST/MASK            NEXTHOP              METRIC     INTERFACE       TYPE
198.51.100.0/16      198.51.100.1         300        Mgmt-oob1       STATIC
198.51.100.0/23      0.0.0.0              1          Mgmt-oob1       LOCAL
192.0.2.0/8          192.0.2.1            300        Mgmt-oob1       STATIC
3 out of 3 Total Num of mgmt ip route displayed
