Use this procedure to configure the device subject parameters to identify the device. The parameters include name, Email ID, company, department, and location of the subject.
This procedure does not apply to VSP 8600 Series.
 - Select Certificate.
 - Select the Subject Entries tab.
 - Select Insert.
 - In the Name field, type the name of the subject.
 - Complete the remaining optional configuration to customize the policy.
 - Select Insert.
Subject Entries Field Descriptions
Use the data in the following table to use the Subject Entries tab.
                                 Name  |
                                 Description  |
                                 Name  |
                            Specifies the user defined name referring to the subject. |
                                 CommonName  |
                                 Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 EmailAddress  |
                                 Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 OrganizationalUnit  |
                                 Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 Organization  |
                                 Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 Locality  |
                                 Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 Province  |
                                 Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 Country  |
                                 Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority.  |
                                 InstallFile  |
                                 Installs the specific certificate file type obtained offline from the Certificate Authority.  |
                                 InstallFileName  |
                                 Specifies the certificate file name to install.  |
                                 UninstallFile  |
                                 Uninstalls the specific certificate file type obtained offline from the Certificate Authority.  |
                                 UninstallFileName  |
                                 Specifies the certificate file name to uninstall.  |
                                 GenerateCsr  |
                                 Generates the certificate signing request to obtain the offline subject certificate.  |
                                 RelaxedMode
                            Note: Exception: Not supported
                                        on VSP 8600
					Series.
                                 Specifies relaxed mode for offline subject certificate installation for less restrictive consistency checks.  |
                                 Pkcs1Password Note: Exception: Not supported on
                                        VSP 8600
					Series.
                                 Specifies the password to extract the PKCS12 container when in relaxed mode.  |
                                 KeyName
                                        on VSP 8600
					Series.
                                 Specifies the key name of the generated key-pair.  |
