Copy files on the internal flash.
 - Select File System.
 - Select the Copy File tab.
 - Edit the fields as required.
 - Select Apply.
Copy File Field Descriptions
Use the data in the following table to use the Copy File tab.
 Name  |
 Description  |
 Source  |
 Identifies the device and file name to copy. You must specify the full path and filename, for
                                    example, <deviceip-ftp
                                        server>:/<filename>
Note:
For certain switches in enhanced secure mode, sensitive files and paths are protected.  |
 Destination  |
                                 Identifies the location to which to copy the source file with the filename, for example, /intflash/<filename>. Note:
 Action  |
 Starts or stops the copy process.  |
 Result  |
 Specifies the result of the copy process:
