- In the navigation pane, expand the following folders: .
 - Click IPv6 PIM.
 - Click the Neighbor Secondary Address tab.
Neighbor Secondary Address field descriptions
Use the descriptions in the following table to use the Neighbor Secondary Address tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor.  |
 Type  |
 Shows the address type of this PIM neighbor.  |
 Primary  |
 The primary IPv6 address of this PIM neighbor.  |
 SecAddress  |
 The secondary IPv6 address of this PIM neighbor.  |
