Use the following procedure to view the Application Telemetry status counters. The switch assigns an ID to each counter and displays information about each filter rule by name. The information includes how many packets were transmitted to the Analytics Engine that matched the specified pattern in the rule and the total number of bytes in the packets.
 - Click Application Telemetry.
 - Click the Counter tab.
Counter field descriptions
Use the data in the following table to use the Counter tab.
                         Name  |
                         Description  |
                         CounterId  |
                         Shows the Application Telemetry rule ID.  |
                         CounterName  |
                         Shows the rule name.  |
                         CounterPkts  |
                         Shows the number of packets transmitted to the Analytics Engine that matched the specified pattern in the rule.  |
                         CounterBytes  |
                         Shows the total number of bytes in the packets.  |
