Use the following procedure to extend the Factory Default Premier Trial License on your switch.
You can run the extend-time-period command up to three times to extend the evaluation license in 30-day increments for an additional 90 days.
This procedure does not apply to VSP 8600 Series.
  1. Enter Privileged EXEC mode:
    enable
  2. Extend the trial software license on your device:
    extend-time-period
    You must reboot your switch after each license extension.
Extend the trial license period for 30-days:
Switch:1>enable
Switch:1#extend-time-period
Are you sure you want to reset the box to apply changes? (y/n) y
