This command displays information for DDI transceivers.
Transceiver support differs across hardware platforms. For information about supported parts, see Extreme Optics website.
Switch:1#show pluggable-optical-modules temperature
                    Pluggable Optical Module Temperature(C)
PORT         LOW_ALARM LOW_WARN    ACTUAL  HIGH_WARN HIGH_ALARM THRESHOLD
NUM          THRESHOLD THRESHOLD   VALUE   THRESHOLD THRESHOLD  STATUS
1/2             7.0       1.1250   65.2539    0.0       3.0156  Low Alarm
1/3             7.0       1.1250   65.2539    0.0       3.0156  Low Alarm
1/9             7.0625    0.0      65.2539    0.0       3.0156  Low Alarm
1/15            7.0625    0.0      65.2539    0.0       3.0156  Low Alarm
2/1             7.0625    0.0      65.2539    0.0       3.0156  Low Alarm
2/17            7.0625    0.0      65.2539    0.0       3.0156  Low Alarm
2/40            7.0625    0.0      65.2539    0.0       3.0156  Low Alarm
Use the data in the following table to use the show pluggable-optical-modules temperature command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
