Use the following procedure to link the security association to an IPsec policy.
The IPsec security association and IPsec policy must exist.
You cannot delete or modify a security association if the security association links to a policy. To modify a parameter in the security association, or to delete the security association, you must first unlink the security association from the policy. You can only unlink a security association from a policy if the policy does not link to an interface. If a policy links to an interface, you must first unlink the policy from the interface, and then unlink the policy from the security association.
Link the IPsec security association named new_sa to the IPsec policy named newpolicy:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ipsec policy newpolicy security-association newsa
The following table defines parameters for the ipsec policy command.
 Variable  |
 Value  |
 WORD<1–32>  |
 Specifies the policy ID.  |
 security-association WORD<1–32>  |
 Specifies the security association ID.  |
