Use the following procedure to retrieve the statistics of the forwarded packets and bytes, and the dropped packets and bytes for the traffic sent toward CP. The queue assignment is based on the protocol types, not on the internal CoS value These statistics are useful for debugging purposes.
 - Click CoS Queue Stats.
 - Select the CPU-Port tab.
CPU-Port Field Descriptions
Use the data in the following table to use the CPU-Port tab.
                                 Name  |
                                 Description  |
                                 Index  |
                                 Indicates the CoS queue number.  |
                                 OutPackets  |
                                 Indicates the out packets for the CPU port.  |
                                 OutBytes  |
                                 Indicates the out bytes for the CPU port.  |
                                 DropPackets  |
                                 Indicates the drop packets for the CPU port.  |
                                 DropBytes  |
                                 Indicates the drop bytes for the CPU port.  |
