Use this procedure to protect additional host names with a single certificate.
The switch supports 100 subject alternative names.
    enable
    configure terminal
  2. Configure a subject alternative name for the entity:
    certificate subject-alternative-name {[dns WORD<1-255>] [e-mail WORD<1-255>] [ip> WORD<1-255>] [subject-name WORD<1-45>]}
    You can configure up to 10 distinct subject names. The default subject name is Global.
  3. View the subject alternative names configured on the switch:
    show certificate subject-alternative-name
Configure a subject alternative name subject name 822:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#certificate subject-alternative-name subject-name 822 dns 822.extremenetworks.com
Switch:1(config)#certificate subject-alternative-name subject-name 822 e-mail name@company.com
Switch:1(config)#certificate subject-alternative-name subject-name 822 ip 192.0.2.22
View the configuration:
Switch:1>show certificate subject-alternative-name
                                   SAN Table
TYPE     NAME                       SUBJECT
E-MAIL   name@company.com           822
DNS      822.extremenetworks.com    822
IP       192.0.2.22                 822
Configure a subject alternative name with the default subject name:
Switch:1>enable
Switch:1(config)#certificate subject-alternative-name dns name@extrnetwk.com
Switch:1(config)#certificate subject-alternative-name e-mail j.smith@extremenetworks.com
Switch:1(config)#certificate subject-alternative-name ip 192.0.2.23
                                        SAN Table
TYPE     NAME                                  SUBJECT
E-MAIL   j.smith@extremenetworks.com           Global
DNS      name@extrnetwk.com                    Global
IP       192.0.2.23                            Global
The following table defines parameters for the certificate subject-alternative-name command.
Variable Value
dns WORD<1-255> Specifies the DNS subject alternative name.
e-mail WORD<1-255> Specifies the e-mail subject alternative name.
ip WORD<1-255> Specifies the IP subject alternative name.
Note:
Exception: Not supported on VSP 8600 Series.
Specifies the Subject Identity Label to be used in local digital certificate request. You can configure up to 10 subject DN identities. If the subject-name is not specified, the default subject name is Global.
