This procedure only applies to the VSP 7400 Series.
Perform the following procedures in sequence to configure the Multi-area SPB feature on the switch.
  1. Configure Remote IS-IS Multi-area SPB Nickname for an SPBM Instance.
  2. Display the Remote IS-IS SPBM Nickname Configuration.
  3. Configure Remote IS-IS Manual Area.
  4. Configure Remote IS-IS System ID.
  5. Configure an IS-IS Area Name
  6. Display IS-IS Remote Area Configuration.
  7. Display IS-IS Area Configuration.
  8. Configure IS-IS Multi-area SPB Virtual Node.
  9. Display IS-IS Area Virtual Node Configuration.
  10. Configure Remote IS-IS Hello Authentication on a Port.
  11. Configure Remote IS-IS Layer 1 Designated Router Priority on a Port.
  12. Configure Remote IS-IS Hello Interval on a Port.
  13. Configure Remote IS-IS Hello Multiplier on a Port.
  14. Configure Remote IS-IS SPBM Parameters on a Port.
  15. Enable Remote IS-IS on a Port.
  16. Enable Remote IS-IS Router Configuration Globally.
  17. Display IS-IS Remote Area Configuration.
  18. Configure Multi-area SPB Layer 2 I-SID List.
  19. Display IS-IS Multi-area SPB Layer 2 I-SID List Information.
  20. Configure Multi-area SPB Layer 2 I-SID Redistribution.
  21. Configure IS-IS Multi-area SPB IPv4 Unicast Redistribution.
  22. Configure IS-IS Multi-area SPB IPv6 Unicast Redistribution.
  23. Configure IS-IS Multi-area SPB IPv4 Unicast Redistribution on a VRF Instance.
  24. Configure IS-IS Multi-area SPB IPv6 Unicast Redistribution on a VRF Instance.
  25. Configure Multi-area SPB DvR Backbone Redistribution.
  26. Display IS-IS Multi-area SPB DvR Configuration.
  27. Configure Multi-area SPB Layer 2 Multicast Snooping Redistribution.
  28. Configure Multi-area SPB IPv4 Routed Multicast Redistribution.
  29. Configure IS-IS Multi-area SPB IPv4 Routed Multicast Redistribution on a VRF Instance.
  30. Configure Multi-area SPB IPv4 Static I-SID Routed Multicast Redistribution.
