Configure Layer 2 IP Ping
Use this procedure to configure Layer 2 IP ping
On the source and destination nodes, you must configure a CFM MD, MA, and MEP, and assign a nodal MEP to the B-VLAN.
If you want to run a Layer 2 IP Ping for a specific VRF, you must use EDM in the specific VRF context first. For more information, see the procedure for selecting and launching a VRF context view in Select and Launch a VRF Context View.
 - Click L2Ping/L2Trace Route.
 - Click the L2 IP Ping tab.
 - To add a new entry, click Insert, specify the destination IP address and optional parameters, and then click Insert.
 - To start the Layer 2 IP ping, highlight an entry, and then click Start.
 - To update the Layer 2 IP ping, click the Refresh button.
 - To stop the Layer 2 IP ping, click Stop.
L2 IP Ping Field Descriptions
Use the data in the following table to use the L2 IP Ping tab.
 Name  |
 Description  |
 IpAddrType  |
 Specifies the address type of destination IP Address (only IPv4 is supported).  |
 IpAddr  |
 Specifies the destination IP Address.  |
 VrfId  |
 Specifies the VRF ID.  |
 VrfName  |
 Specifies the name of the virtual router.  |
 Messages  |
 Specifies the number of L2IpPing messages to be transmitted per MAC/VLAN pair. Range is 1–200. The default is 1.  |
 Status  |
 Specifies the status of the transmit loopback service:
 This field is also used to avoid concurrency or race condition problems that could occur if two or more management entities try to use the service at the same time. The default is ready.  |
 ResultOk  |
 Indicates the result of the operation:
 The default is true.  |
 TimeoutInt  |
 Specifies the interval to wait for an L2IpPing time-out with a range of 1–10 seconds with a default value of 3 seconds.  |
 TestPattern  |
 Specifies the test pattern to use in the L2IPPing PDU:
 A cyclic redundancy check is a code that detects errors. The default value is allZero.  |
 DataSize  |
 Specifies an arbitrary amount of data to be included in the data TLV, if the data size is selected to be sent. The range is 0–400. The default is 0.  |
 PathsFound  |
 Specifies the number of paths found to execute the command. The default is 0.  |
