View ACE Statistics
View ACE statistics to ensure that the filter operates correctly.
View ACE statistics:
Based on your hardware platform, the output can display the ACL packets by ACE type or Primary Bank or Secondary Bank.
Switch:1>enable
Switch:1#show filter acl statistics all
                          Acl Global Statistics Table
Acl Id  Acl Name    Acl Type  Acl Sec    Acl Sec    Acl QOS    Acl QOS   Acl      Acl
                              Packets    Bytes      Packets    Bytes     Packets  Bytes
1       ACL-1       inVlan    0          0          0          0         0        0
2       ACL-2       inVlan    0          0          0          0         0        0
Displayed 2 of 2 entries
                          Acl Default Statistics Table
Acl Id  Acl Name    Acl Type  Primary Bank  Primary Bank  Secondary Bank   Secondary Bank   Acl       Acl
1       ACL-1       inVlan    1360		 92480            1360             92480            2720      184960
Displayed 1 of 1 entries
IPv4 policer statistics for red, yellow, and green packets are available on VSP 7400 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1#show filter acl statistics 3 3 policer
                             Acl Ace Policer Table
Acl Id  Ace Id  Packets    Bytes      Green      Green      Yellow     Yellow     Red        Red
3       3    29964026      106591916  142584     14254      142574     277225     28869904   10275810600
            View filter acl ace policer statistics on VSP 4900 Series.
Only IPv4 policer statistics for red packets are available on VSP 4900 Series. Yellow and green packet counters are not supported on VSP 4900 Series. Statistics display as numbers, which represent the hit number of packets and bytes.
Switch:1(config)#show filter acl statistics 3 3 policer
3         3        29964026    106591916   N/A       N/A     N/A        N/A       28869904  10275810600
            View filter acl ace statistics with no policer configured.
10         1001      0            0           N/A        N/A      N/A        N/A        N/A       N/A
            View filter acl ace statistics with filter ACE enabled and policer configured, but the filter is not hit or there is no traffic running.
Switch:1(config)#show filter acl statistics 10 1011
3         3       0            0           0          0         0          0        0          0
            View filter acl ace statistics with filter ACE not enabled and policer not configured
The following table defines parameters for the show filter acl statistics command.
 Variable  |
 Value  |
 <acl-id>  |
 Specifies the ACL ID. Use the CLI Help to see the available range for the switch.  |
 <ace-id>  |
 Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.  |
                             policer Note:
                        Exception: only supported on VSP 4900 Series and VSP 7400 Series.  |
                             Specifies the policer parameter for the command.  |
