Perform this procedure to enable Energy Saver or EEE on one or more ports.
 - Select Energy Saver.
 - Select the Ports tab.
                Enable either Energy Saver or EEE:
To enable Energy Saver, in the EnergySaverEnabled column, double-click the field associated with the specific ports, and then select true.
To enable EEE, in the EnergySaverEEEEnable column, double-click the field associated with the specific ports, and then select true.
 - Select Apply.
Energy Saver Field Descriptions
Use the data in the following table to use the Energy Saver tab.
 Name  |
 Description  |
 Port  |
 Specifies the port number.  |
 EnergySaverEnabled  |
 Configures whether Energy Saver is enabled on the specific port.  |
 EnergySaverPoEStatus  |
 Specifies Energy Saver PoE status for the specific port.  |
             EnergySaverEEEEnable  |
                         Configures whether EEE is enabled on the specific port.  |
