Use the following procedure to clear all OSPFv3 statistics.
Use the data in the following table to use the clear ipv6 ospf stats command.
                             Variable  |
                             Value  |
                             vrf WORD<1-16>  |
                             Specifies the VRF name.  |
                             vrfids WORD<0-512>  |
                             Specifies VRF IDs.  |
