Enable RADIUS authentication globally to allow all features and functions of RADIUS to operate with the RADIUS server.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select RADIUS.
  3. Select the RADIUS Global tab.
  4. Select Enable.
  5. In the MaxNumberServer field, type a value for the maximum number of servers.
  6. In the AccessPriorityAttrValue field, type an access policy value (by default, this value is 192).
  7. Configure the rest of the parameters in the RADIUS global tab.
  8. Select Apply.
RADIUS Global Field Descriptions
Use the data in the following table to use the RADIUS Global tab.
Name
Description
Enable
Enables the RADIUS authentication feature globally.
MaxNumberServer
Specifies the maximum number of servers to be used, between 1 and 10, inclusive.
Specific to RADIUS authentication. Specifies the vendor-specific attribute value of the access-priority attribute to match the type value set in the dictionary file on the RADIUS server. The valid values are 192 through 240. The default is 192.
AcctEnable
Enables RADIUS accounting.
AcctAttriValue
Specific to RADIUS accounting. Specifies the vendor-specific attribute value of the CLI-command attribute to match the type value set in the dictionary file on the RADIUS server. This value must be different from the access-priority attribute value configured for authentication. The valid values are 192 through 240. The default value is 193.
AcctIncludeCli
Specifies whether you want CLI commands included in RADIUS accounting requests.
ClearStat
Clears RADIUS statistics from the device.
McastAttributeValue
Specifies the value of the Mcast attribute. The valid values are 0 through 255. The default value is 90.
AuthInfoAttrValue
Specifies the value of the authentication information attribute. The valid values are 0 through 255. The default value is 91.
CommandAccessAttrValue
Specifies the value of the command access attribute. The valid values are 192 through 240. The default value is 194.
CliCommandAttrValue
Specifies the value of the CLI command attribute. The valid values are 192 through 240. The default value is 195.
AuthInvalidServerAddress
Displays the number of access responses from unknown or invalid RADIUS servers.
SourceIpFlag
Note:
Exception: only supported on VSP 8600 Series.
Includes a configured IP address as the source address in RADIUS packets. The default is false. RADIUS supports IPv4 and IPv6 addresses with no difference in functionality or configuration.
CliCmdCount
Gives the value for the CLI command count. Specify an integer from 1 to 40. The default is 40.
CliProfEnable
Enables RADIUS CLI profiling.
SupportedVendorIds
Shows the vendor IDs that the software supports for RADIUS.
RadiusReachability
Specifies the mode for RADIUS reachability. Status-server mode provides a standard-compliant method for RADIUS reachability. Use-radius mode requires the configuration of dummy packets that are sent to RADIUS servers. The default is use-radius mode.
SecureEnable
Enable RADIUS Security (RADSec).
UserName
Specifies the username for RADIUS server reachability. The default is extremenetworks.
Password
Specifies the password for RADIUS server reachability. The default is extremenetworks.
Confirm Password
Confirms the password for RADIUS server reachability.
Unreachable Timer
Specifies, in seconds, the interval between checks when radius server is unreachable. The default is 60 seconds.
Keep Alive Timer
Specifies, in seconds, the interval between checks when radius server is reachable. The default is 180 seconds.
