View the VLACP port configuration to show the port VLACP configuration.
Switch:1>show vlacp interface gigabitethernet
                               VLACP Information
INDEX ADMIN   OPER    PORT     FAST  SLOW   TIMEOUT TIMEOUT ETHER      MAC
      ENABLED ENABLED STATE    TIME  TIME   TIME    SCALE   TYPE       ADDR
1/1   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/2   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/3   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/4   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/5   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
--More-- (q = quit)
                         VLACP Flap Detect Information
INDEX FLAP    FLAP    FLAP     TOTAL      FIRST-FLAP      LAST-FLAP
      DETECT  FREQ    INTERVAL FLAP       TIME            TIME
1/1   false   3       60       0          -- --           -- --
1/2   false   3       60       0          -- --           -- --
1/3   false   3       60       0          -- --           -- --
1/4   false   3       60       0          -- --           -- --
1/5   false   3       60       0          -- --           -- --
--More-- (q = quit)
Switch:1>show vlacp interface gigabitethernet 2/11 vid 2
		                                  VLACP Information
2/11    true      true     up     500     30000  short     3       0x8103   01:80:c2:00:00:0f
2/11      true       10      10	      4	  09/20/11 08:24:10    09/20/11 08:26:10
Switch:1>show vlacp interface gigabitethernet 1/7
                               VLACP Information
1/7   false   false   DOWN  200     30000    long     3      0x8103    01:80:c2:00:11:00
1/7   false   3       60       0          -- --           -- --
      Variable definitions
Use the data in the following table to use the show vlacp interface gigabitethernet command.
 Variable  |
 Value  |
 vid <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. The VLAN ID is in one of the following formats: A single VLAN ID (vlan-id), a range of VLAN IDs [(vlan-id)-(vlan-id)] or a series of VLAN IDs (vlan-id, vlan-id, vlan-id).  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Specifies a port or list of ports to show only the VLACP information for those ports. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
