You can view information about the temperature on the chassis.
This procedure only applies to the VSP 8600 Series.
The system triggers an alarm when one of the zones exceeds the threshold temperature value, and clears the alarm after the zone temperature falls below the threshold value.
When an elevated temperature triggers a temperature alarm, the fan speed increases, and the LED color changes on the front panel of the switch.
- In the Device Physical View tab, select the chassis.
 - Select Chassis.
 - Select the Temperature tab.
Temperature field descriptions
Use the data in the following table to use the Temperature tab.
 Name  |
 Description  |
 CpuTemperature  |
 Current CPU temperature in Celsius.  |
 MacTemperature  |
 Current MAC component temperature in Celsius.  |
 Phy1Temperature  |
 Current PHY 1 component temperature in Celsius. This field does not apply on all hardware platforms.  |
 Phy2Temperature  |
 Current PHY 2 component temperature in Celsius. This field does not apply on all hardware platforms.  |
