You can view each port and associated VRFs. You can also change the VRFs associated with the port if the port has no IP address.
VRF-Ports field descriptions
Use the data in the following table to use the VRF-Ports tab.
 Name  |
 Description  |
 Index  |
 Specifies the slot and port.  |
 Type  |
 Specifies the port type.  |
 VrfIds  |
 Identifies the set of VRF IDs to which this port belongs.  |
 VrfCount  |
 Shows the number of VRF instances associated with this port.  |
 BrouterVrfId  |
 Shows the VRF ID for this brouter port.  |
 BrouterVrfName  |
 Shows the VRF name for this brouter port.  |
 Show VrfNames  |
 You can use this toolbar button to identify the set of VRF names to which a port belongs.  |
Use the data in the following table to use the Show VrfNames button.
 Name  |
 Description  |
 Index  |
 VrfNames  |
