Use this procedure to view NEAP client MAC information on a port.
- In the navigation pane, expand Configuration --> Security --> Data Path.
 - Select 802.1X – EAPOL.
 - Select NEAP Radius tab.
NEAP Radius Field Descriptions
The following table describes values on the NEAP Radius tab.
 Name  |
 Description  |
 MacPort  |
 Indicates the port number associated with this port.  |
 MacAddr  |
 Indicates the MAC address of the client.  |
 MacStatus  |
 Indicates the authentication status of the NEAP host that is authenticated using the RADIUS server.  |
 VlanId  |
 Indicates the VLAN assigned to the client.  |
 MacClear  |
 Clears the non EAP MAC entry associated with a specific index.  |
 MacPriority  |
 Indicates the priority associated with this Non-EAP client MAC. This priority could be the Radius assigned priority or the port QOS level.  |
                                 SwUniBindings Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the VLAN and I-SID bindings. VLAN is represented with 2 bytes and I-SID is represented with 4 bytes. The output is a continuous hexadecimal representation of the VLAN that is followed by the corresponding I-SID.  |
                                 IsidSource Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the source of the I-SID value. An I-SID value is generated in one of the following ways:
                                 NonEapAuthType Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the authentication type of the Non-EAP client:
                                 AclId Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the dynamic Access Control List (ACL) on the specific port.  |
                                 AceIdList Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the list of dynamic Access Control Entries (ACE) on the specific port.  |
                                 DynamicSettings  |
                                 Displays the Dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server.  |
