This procedure does not apply to VSP 8600 Series.
Use this task to view IPv4 Address Resolution Protocol (ARP) information.
 - Expand Mgmt Instance.
 - Select Mgmt.
 - Select the IpArp tab.
IpArp Field Descriptions
Use the data in the following table to use the IpArp tab.
 Name  |
 Description  |
 Address  |
 Shows the IPv4 address of the ARP entry.  |
 Instance  |
 Shows the Management Instance ID.  |
 IntfName  |
 Shows the Management Instance interface name for the ARP entry.  |
 MacAddr  |
 Shows the MAC address for the ARP entry.  |
 State  |
 Shows the state of the ARP entry. The state can be one of the following:
