Perform this procedure to configure network policies on specific ports.
Configuring guest voice network policy on port 1/2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#lldp med-network-policies guest-voice dscp 1 priority 5 tagging tagged vlan-id 5
The following table defines parameters for the lldp med-network-policies command.
 Variable  |
 Value  |
 {guest-voice | guest-voice-signaling | softphone-voice | streaming-video | video-conferencing | video-signaling | voice | voice-signaling}  |
 Specifies the type of network policy.  |
 dscp <0-63>  |
 Specifies the Layer 3 DiffServ Code Point (DSCP) value, as defined in IETF RFC 2474 and RFC 2475. The default is 0.  |
 priority <0-7>  |
 Specifies the priority level, as defined in IEEE 802.1D. The default is 0.  |
 tagging {tagged | untagged}  |
 Specifies the type of VLAN tagging to apply on the selected ports. The default is untagged.  |
 vlan-id <0-4059>  |
 Specifies the VLAN ID for the port, as defined in IEEE 802.1Q. If you configure priority tagged frames, the system recognizes only the 802.1D priority level and uses a value of 0 for the VLAN ID of the ingress port. The default is 0.  |
