                                 Feature  |
                                 Product  |
                                 Release introduced  |
                                 MSTP-Fabric Connect Multi Homing  |
                                 VSP 4450 Series  |
                                 VOSS 7.0  |
                                 VSP 4900 Series  |
                                 VOSS 8.1  |
                                 VSP 7200 Series  |
                                 VOSS 7.0  |
                                 VSP 7400 Series  |
                                 VOSS 8.0  |
                                 VSP 8200 Series  |
                                 VOSS 7.0  |
                                 VSP 8400 Series  |
                                 VOSS 7.0  |
                                 VSP 8600 Series  |
                                 Not Supported  |
                                 XA1400 Series  |
                                 Not Supported  |
The MSTP-Fabric Connect Multi Homing feature allows MSTP or RSTP network to be multi-homed into a Fabric Connect network, providing a loop-free topology. MSTP-Fabric Connect Multi Homing enables an MSTP network to be multihomed into the SPB Fabric network through single node-to-multiple nodes or multiple nodes-to-multiple nodes.
Important
You must enable MSTP-Fabric Connect Multi Homing before you establish multihoming with an MSTP network.
MSTP-Fabric Connect Multi Homing uses I-SID 16777003. The switch creates this I-SID automatically and it cannot be modified.
MSTP-Fabric Connect Multi Homing is supported on SPBM mode only.
