Perform this procedure to create a DvR domain with the domain ID that you specify, and configure the role of the node as a Leaf node. Configuring a node as a DvR Leaf automatically enables DvR globally on the node.
A Leaf node can belong to only one DvR domain.
For a node to perform the role of both a Controller and a Leaf within the domain, you must configure it as a Controller.
You must enable the VRF-scaling boot configuration flag on a DvR Leaf node, if more than 24 VRFs are required in the DvR domain.
For additional scaling information, see VOSS Release Notes.
You must enable the dvr-leaf-mode boot flag before you configure a node as a DvR Leaf node.
When you enable the dvr-leaf-mode boot flag, you can configure the node as a DvR leaf node without rebooting, as long as there is no unsupported configuration discovered on the switch.
To verify the setting, enter show boot config flags in Privileged EXEC mode.
Caution
Ensure that you save the current configuration on the switch, before you enable the flag.
Enabling the flag removes all existing non-DvR configuration on the switch, such as platform VLANs and their IP address configuration, circuitless IP (CLIP) configuration, routing protocol configuration and VRF configuration. The gateway IPv4 address, if configured, is also removed.
Configure a node as a DvR Leaf:
Switch2:1>enable Switch2:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch2:1(config)#boot config flags dvr-leaf-mode Switch2:1(config)#save config Switch2:1(config)#dvr Leaf 5
Switch2:1(config)#show dvr
                      DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678219
Role                           : Leaf
My SYS ID                      : 00:00:72:54:44:00
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
Inband Mgmt Clip IP            :
Virtual Ist local address      :
Virtual Ist local subnet mask  :
Virtual Ist peer address       :
Virtual Ist cluster-id         :
Virtual Ist ISID               :
                      Variable definitions
Use the data in the following table to use the dvr leaf command.
 Variable  |
 Value  |
 <1-255>  |
 Specifies the domain ID of the DvR domain to which the Leaf node belongs.  |
