Use the following procedure to add devices with a specified MAC address to the DHCP Snooping binding table.
Switch:1>enable Switch:1#configure terminal Switch:1(config)# ip dhcp-snooping binding 1 00-14-22-01-23-45 ip 10.10.10.01 port 1/2 expiry 2
The following table defines parameters for the ip dhcp-snooping binding command.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID.  |
 0x00:0x00:0x00:0x00:0x00:0x00  |
 Specifies the MAC address of the DHCP client.  |
 ip {A.B.C.D}  |
 Specifies the IP address of the DHCP client.  |
 port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Specifies the switch port to which the DHCP client connects.  |
 expiry <0-2147483646>  |
 Specifies the expiry time (in seconds) for the DHCP client.  |
