This section describes how to configure the Network Time Protocol (NTP) using Enterprise Device Manager (EDM).
Before you configure NTP, you must perform the following task:
NTPv3 does not use the Segmented Management Instance. For NTPv3, configure a traditional IP interface on the switch and ensure that the NTP server is reachable through this interface.
NTPv3 is only supported on VSP 8600 Series.
For NTPv4, you must create a Segmented Management Instance and configure routing for that instance.
Important
Important
NTP server MD5 authentication or SHA1 authentication does not support passwords (keys) that start with a special character or that contain a space between characters.
This task flow shows you the sequence of procedures you perform to configure NTP.
NTP Configuration Procedures
