View all DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
Ensure that you enable DvR on the node.
 - Click DVR.
 - Click the Database tab.
 - Optional: To filter the rows based on the specific criteria, click Filter.
Database field descriptions
Use the data in the following table to use the Database tab.
 Name  |
 Description  |
 DestIpAddrType  |
 Specifies the address type of the IPv4 destination address of the DvR database entry.  |
 DestIpAddr  |
 Specifies the IPv4 destination address of the DvR database entry.  |
 DestMask  |
 Specifies the destination mask of the DvR database entry.  |
 L3Isid  |
 Specifies the Layer 3 I-SID of the DvR database entry.  |
 EcmpIndex  |
 Specifies the ECMP index for the DvR database entry.  |
 NextHop  |
 Specifies the MAC address of the next hop BEB, in the DvR database entry.  |
 L2Isid  |
 Specifies the Layer 2 I-SID of the DvR database entry.  |
 VrfId  |
 Specifies the VRF ID for the DvR database entry.  |
 OutgoingInterface  |
 Specifies the outgoing interface (port or MLT) of the DvR database entry.  |
 SpbCost  |
 Specifies the SPB cost of the DvR database entry.  |
 PrefixCost  |
 Specifies the prefix cost of the DvR database entry.  |
 NextHopName  |
 Specifies the host name of the next hop BEB, in the DvR database table entry.  |
 Age  |
 Specifies the uptime since creation of the DvR database table entry.  |
