Check OSPF errors for administrative and troubleshooting purposes.
Variable definitions
The following table defines parameters for the show ip ospf port-error command.
 Variable  |
 Value  |
 {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 vrf WORD<1-16>  |
 Specifies the VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRFs by ID number.  |
