View the table of default routers learned from router advertisement messages.
A maximum of four routers are visible in the default routers list.
This procedure does not apply to VSP 8600 Series.
- In the navigation tree, expand the folders.
 - Click IPv6.
 - Click the Default Routers tab.
Default Routers field descriptions
Use the data in the following table to use the Default Routers tab.
 Name  |
 Description  |
 Address  |
 Specifies the learned router address for an IPv6 default routers entry.  |
 IfIndex  |
 Specifies the interface number for an IPv6 default routers entry.  |
 Lifetime  |
 Specifies the remaining router lifetime.  |
 Active  |
 Specifies if the default router is active for an IPv6 default routers entry.  |
