Perform this task to run a virtual machine (VM) command from the NOS CLI.
    enable
    configure terminal
  2. Run the ls command for the VM configs directory from the CLI:
    virtual-service WORD<1-128> exec-command WORD<1-256>
  3. Run a Fabric IPsec Gateway command from the CLI:
    virtual-service WORD<1-128> figw-cli WORD<1-256>
    To use this command, the Fabric IPsec Gateway image must be at least 5.0.0.0.
From NOS, list the contents of the home/rwa/configs directory in the Fabric IPsec Gateway VM:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#virtual-service figw exec-command "ls /home/rwa/configs"
config.cfg
figw_cli.log
shadov.txt
From NOS, configure the source VLAN ID for the IPsec tunnel in the Fabric IPsec Gateway VM:
Switch:1>enable
Switch:1(config)#virtual-service figw figw-cli "set global ipsec-tunnel-src-vlan 71"
