Enable SSH globally.
Switch:1>enable Switch:1#configure terminal
Enable SSH rekeying globally:
Switch:1(config)#ssh rekey enable
The following table defines parameters for the ssh rekey command.
 Variable  |
 Value  |
 enable  |
 Enables SSH rekey globally.  |
