This procedure does not apply to
VSP 8600
					Series and
XA1400
					Series.
            Perform this procedure to enable Auto-sense on one or more ports.
            If you select more than one port, the format of the tab changes to a table-based
                tab.
                    - After a switch boots without a configuration file, Auto-sense is enabled on all
                        ports, by default.
                    - Auto-sense is disabled by default for existing configurations but enabled for new
                        Zero Touch Fabric Configuration deployments.
                    - Auto-Sense cannot be enabled when the spbm-config-mode flag is false.
                In the Device
                        Physical View tab, select one or more ports.
                In the navigation pane, expand
                Select General.
                Select the Interface tab.
                For AutoSense, select
                    enable.
                Select Apply.
