Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Enables VXLAN Gateway in Full Interworking Mode, which supports SPB, SMLT, and vIST.
Important
Important
After you change this boot flag, you must save the change to the configuration file and reboot the switch.
By default, the Base Interworking Mode is enabled and Full Interworking Mode is disabled. You change modes by enabling this boot configuration flag.
The no operator results in the default Base Interworking Mode. In this mode, VXLAN Gateway supports Layer 2 gateway communication between VXLAN and traditional VLAN environments.
    enable
    configure terminal
  2. Enable Full Interworking Mode:
    boot config flags vxlan-gw-full-interworking-mode
  3. Save the changed configuration.
    save config
  4. Restart the switch.
    reset
  5. Verify that VXLAN Gateway is in Full Interworking Mode:
    show boot config flags
    The true parameter in the output indicates that Full Interworking Mode is enabled.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#boot config flags vxlan-gw-full-interworking-mode
