View IPv6 statistics to view information about the IPv6 datagrams on an interface.
  1. To enter User EXEC mode, log on to the switch.
  2. View statistics:
    show ipv6 interface statistics [gigabitethernet <slot/port[/sub-port]> | loopback <1–256> | mgmtethernet mgmt | tunnel <1-2000> | vlan <1-4059>] [vrf WORD<1–16>] [vrfids WORD<0–512>]
    The mgmtethernet mgmt parameter is only supported on VSP 8600 Series.
View IPv6 statistics on an interface:
Switch:1>enable
Switch:1#show ipv6 interface statistics
                                Interface Stats
If Stats for mgmt, IfIndex = 64
InReceives: 404
InHdrErrors: 0
InTooBigErrors : 0
InNoRoutes : 0
InAddrErrors : 0
InUnknownProtos : 0
InTruncatedPkts : 0
InDiscards : 0
InDelivers : 404
OutForwDatagrams : 0
OutRequests : 417
OutDiscards : 0
OutFragOKs : 0
OutFragFails : 0
OutFragCreates : 0
--More-- (q = quit)
Use the data in the following table to use the show ipv6 interface statistics command
Variable
Value
gigabitethernet {slot/port[/sub-port]}
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
loopback <1–256>>
Identifies a loopback interface.
mgmtethernet mgmt
Note:
Exception: only supported on VSP 8600 Series.
Identifies the management interface. This parameter only applies to hardware with a dedicated, physical management interface.
tunnel <1-2000>
Identifies a 6in4 tunnel ID.
vlan <1-4059>
Shows statistics for the specific interface index. If you do not specify an interface index, the command output includes all IPv6 interfaces.
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
vrf WORD<1–16>
Specifies the VRF name.
vrfids WORD<0–512>
Specifies the VRF ID.
